IP voltmeter v2.5 is a universal device for measuring DC voltage over the Internet.
Designed by Digital Measure in Slovakia
IP voltmeter - 8 channel IP voltmeter is a universal device for measuring DC voltage in a local network or over the Internet. The use is mainly in measuring and monitoring voltage at a distance. It …
Read More…IP voltmeter is a universal device for measuring DC voltage in a local network or over the Internet. The use is mainly in measuring and monitoring voltage at a distance. It is suitable e.g. for measuring batteries in solar systems and other devices that are powered by batteries. This board contains 8x DC voltmeters that are completely independent. All inputs are galvanically separated from the board and allow to measure voltage in all configurations: source with a common ground or 8 completely independent sources. The IP voltmeter also has other advanced functions such as an alert, sending data to the cloud (ThingSpeak) or to a remote database.
Data can be read in different ways. Via web browser, TCP client, SNMP client, reading XML file.
Data can also be read via SNMP protocol. The device contains an SNMP agent v2...
The TCP/IP voltmeter contains a TCP server that listens on port 9760. It is possible to read the measured data using a TCP client.
Data can be sent to the Thingspeak.com cloud. ThingSpeak is an cloud service that allows you to store, visualize and analyze your measured data.
TCP voltmeter contains a TCP client that can send data to a remote database using the POST method.
The device allows you to send an alert if the value of any voltage reaches a certain set value.
The TCP voltmeter can have a dynamic IP address or a static IP address. The dynamic IP address is obtained from the DHCP server, the static address can be configure in Network Settings manually.
the board supports well-known DNS services : noip.com , dyndns.com.
Enter your email address if you'd like to be notified when IP voltmeter - 8 channel can be shipped to you:
