2-Channel 500kS/s Wi-Fi oscilloscope with FFT, X-Y mode, cursors and signal generator
Designed by Yezzmod Audio in AustraliaThis product is no longer available for sale.
The DSO-500K is a 2-Channel 500kS/s oscilloscope with a maximum analog bandwidth of 150kHz. The highly rated Scoppy Android app is used to control the scope and display the waveform data. The oscillo…
Read More…The DSO-500K is a 2-Channel 500kS/s oscilloscope with a maximum analog bandwidth of 150kHz. The highly rated Scoppy Android app is used to control the scope and display the waveform data. The oscilloscope connects to your Android device via USB or Wi-Fi.
The hardware is open source and you are free to install your own firmware onto the embedded Pico W board (however, if you do this you are on your own as we can't provide support for custom firmware).
The DSO-500K supports AUTO and NORMAL trigger modes and RISING EDGE and FALLING EDGE trigger types. The trigger level is set either by dragging the trigger indicator, tapping the trigger level buttons or tapping the trigger badge at the bottom of the screen. Long-pressing the LEVEL button will set the trigger level to the center of the displayed waveform.
Horizontal and vertical cursors are available in both YT (ie. normal oscilloscope) and FFT modes. In YT mode, the horizontal (X) cursor measurements include position, period and frequency. Vertical (Y) cursor measurements include the voltage and the delta between the two cursors.
Standard X-Y mode as found on most oscilloscopes. Also includes a LINES option to join all samples points with lines instead of displaying individual dots. This can make the output look much nicer for some signals.
The X-Y mode view can be displayed simultaneously with the YT waveforms.
Displays the waveform data as it is captured instead of waiting for the complete waveform record. Roll mode is automatically activated when the Time/Div setting is 100ms/div or more.
Pressing the SINGLE button will capture a single waveform record of up to 100k samples. Can be used with either AUTO triggering (to capture the waveform immediately) or NORMAL triggering (to capture the waveform after a trigger event occurs).
Headers can be soldered to the board to access the Logic Analyzer inputs. The logic analyzer sample rate is 25MS/s and the maximum voltage is 3.3V.
Protocol decoding is not available but the waveform record can be saved and imported into other software (eg. sigrok/pulseview).
Removing the jumpers from the DC coupling pins will enable AC coupling.
On screen measurements include Vmin, Vmax, Vpp, Frequency, Time (Period) and Duty Cycle for each channel. Tapping the measurements will open the configuration screen. The configuration screen can also be accessed via the channel badges.
Measurements can be displayed for a single waveform (snapshot). These snapshot measurements can encompass the entire sample record or just those samples displayed on the screen. The measurements available include Vmin, Vmax, Vpp, Vmean, Vdc-rms, Vac-rms, Frequency, Period and Duty Cycle. The snapshot measurements can be displayed by long-pressing the on-screen measurements or via the channel badges.
The signal generator can produce square waves of between 10Hz and 1MHz or a PWM encoded sine wave of 1kHz. The PWM encoded sine wave can be converted to an analog sine wave using the onboard low pass filter.
Detailed documentation is available for the app and hardware. While the intuitive user interface of the Scoppy Android app means it can easily be used without consulting the documentation, you might - for example - be interested in discovering the five different ways of changing the horizontal timebase. We encourage you to check out the independent reviews of the app on the Play Store.
1 | $29.99 |
2+ | $19.99 |
Mark | June 9, 2023
$590.00
$155.00
$26.00
$300.00
