BMO NRF Module for the Flipper Zero
Designed by FlipperHub in Germany
Introducing the BMO NRF module for Flipper Zero, featuring the Ebyte E01-2G4M27SX, a compact and powerful 2.4GHz SMD wireless module based on the Nordic nRF24L01P chipset. This module is specifically…
Read More…Introducing the BMO NRF module for Flipper Zero, featuring the Ebyte E01-2G4M27SX, a compact and powerful 2.4GHz SMD wireless module based on the Nordic nRF24L01P chipset. This module is specifically engineered to boost the wireless capabilities of your Flipper Zero device, enabling robust communication over significant distances.
High-Performance Chipset: Uses the original imported nRF24L01P from Nordic in Norway, ensuring top-notch reliability and compatibility.
Powerful Transmission: With a maximum output power of 27dBm (or 500mW), it provides substantial reach with a transmission distance of up to 4km (max range not tested).
Operating Frequency: Operates within a frequency range of 2.4 to 2.525 GHz, perfect for high-density wireless applications.
External Antenna: comes with a 2dBi antenna and the option to attach any other 2.4ghz sma antenna
Ultra-Compact Design space-efficient.
⚠️ WARNING ⚠️
This hardware is for educational and experimental purposes only and is not meant for any illegal activity or purposes.I do not condone illegal activity and strongly encourage keeping transmissions to legal or valid educational or experimental uses allowed by law.Please be advised that the products sold here are third-party items that are compatible with the Flipper Zero. These products are not manufactured, endorsed, or affiliated with Flipper Devices Inc. in any way. The use of the Flipper or Flipper Zero name in our product descriptions is for identification purposes only, to demonstrate the compatibility of our products with the mentioned device
Enter your email address if you'd like to be notified when BMO NRF - For the Flipper Zero can be shipped to you:
$173.25
$49.80
$11.90
$11.90
$38.90
$49.80
$45.99
$26.99
