10 Pins Flat Ribbon Cable 2.54mm pitch JTAG with IDC Female Socket 10p, short 10cm. Use to connect between multiplexer boards
Designed by FLOW_STATE in United States of America
10 pin Flat Ribbon Cable Connectors. 2.54mm pitch. These cables are terminated with a female IDC connector, JTAG style. Select from 6 different lengths: 10cm, 20cm, 30cm, 50cm, 70cm, or 100cm. Ribbon…
Read More…10 pin Flat Ribbon Cable Connectors. 2.54mm pitch. These cables are terminated with a female IDC connector, JTAG style. Select from 6 different lengths: 10cm, 20cm, 30cm, 50cm, 70cm, or 100cm. Ribbon Cables are gray with a red edge indicating pin 1 on the connector
use this short cable to daisy-chain connection between stacked multiplexer boards
Enter your email address if you'd like to be notified when 10 Pins Flat Ribbon Cable 2.54mm pitch JTAG can be shipped to you:
$4.50
