Screw Terminal Board with Mountable Enclosure for Arduino Nano. Has GND terminals for digital I/O, GND and 5v terminals for analog inputs
Designed by FLOW_STATE in United States of America
This is a screw terminal break out board for an arduino nano, with an enclosure. This product comes assembled with screw terminals, and female header strips, and plastic enclosure with screws. Includ…
Read More…This is a screw terminal break out board for an arduino nano, with an enclosure. This product comes assembled with screw terminals, and female header strips, and plastic enclosure with screws. Includes Arduino Nano. This screw terminal board is designed with easy access to 5v and GND pins. Each digital input screw terminal has a ground screw terminal next to it, making for easy and convenient sensor wiring. Each Analog input has a 5V and GND screw terminal next to it, making for easy wiring with potentiometers and other sensors.
This product has a plastic enclosure for protection, as well as 4 holes ( 3mm diameter ) for mounting this enclosure. This screw terminal enclosure is great for proto-typing or hobby project, with quick as easy access to screw terminal, as well as adding protection to the board with the enclosure, and holes to easily mount this enclosure onto a board or wall, or inside a box.
This product has a ground screw terminal placed next to every input, and a 5v screw terminal next to every analog input. These extra terminals are quite useful, making wiring simpler, and avoiding a power bus or grounding bus.
Enter your email address if you'd like to be notified when Arduino Nano Breakout Board with Screw Terminals can be shipped to you:
$1.00
