Versatile USB to serial module with 3.3V/5V compatibility for easy connectivity.
Designed by Forgelab in Romania
What is it? The USB-C CH340 adapter is a USB-to-serial module designed for reliable 3.3V and 5V communication. It bridges USB-C devices with microcontrollers, making it a versatile tool for developer…
Read More…What is it?
The USB-C CH340 adapter is a USB-to-serial module designed for reliable 3.3V and 5V communication. It bridges USB-C devices with microcontrollers, making it a versatile tool for developers and makers.
Why did you make it?
We wanted a modern, compact solution to simplify serial communication with USB-C compatibility. The goal was to provide an adapter that works seamlessly with both legacy and modern hardware.
What makes it special?
It supports both 3.3V and 5V logic levels, making it compatible with a wide range of devices. The USB-C connector ensures durability, ease of use, and compatibility with modern systems.
Enter your email address if you'd like to be notified when USB-C to serial converter, CH340 can be shipped to you:
