Its an Arduino IDE compatible Wifi ESP8266-12E onboard LED module.
Designed by Fred in ChinaThis seller is taking a break. Sign up below to get an email when they're back!
Introduction: It’s a Arduino-compatible , WiFi-enabled portable board, it has SSD1306 0.96” Monochrome OLED screen directly soldered onto the board which makes it compact and portable. It allows use…
Read More…Introduction: It’s a Arduino-compatible , WiFi-enabled portable board, it has SSD1306 0.96” Monochrome OLED screen directly soldered onto the board which makes it compact and portable. It allows users to use Arduino IDE (Integrated Development Environment) interface to upload sketches directly. To make it compact and portable we had to separate FTDI ( USB To TTL) that makes it cheaper and affordable.
Its an ESP8266 and SSD1306 based hardware! Can be used as a badge or simple wifi IOT home display. USB to TTL cable included!
If you have suggestion or need to modify this hardware design for larger quantity! Pleas feel free to contact me.
Pins for OLED and ESP8266: const int I2C_DISPLAY_ADDRESS = 0x3c const int SDA_PIN = 13 const int SDC_PIN = 12
Enter your email address if you'd like to be notified when ESP8266 OLED Display Module SSD1306 I2C can be shipped to you:
$43.00
$19.95
$39.90
