5 x PCB Breakout Boards for Winsen ZE07-CO/ZE15-CO Carbon Monoxide sensor modules.
Designed by GA-MECATRONICS in France
What is it ? 5 x PCB Breakout Boards for Winsen ZE07-CO/ZE15-CO Carbon Monoxide sensor modules. The pinout spacing of the Winsen sensor module boards are smaller than standard (2.00mm) which makes it…
Read More…What is it ?
5 x PCB Breakout Boards for Winsen ZE07-CO/ZE15-CO Carbon Monoxide sensor modules. The pinout spacing of the Winsen sensor module boards are smaller than standard (2.00mm) which makes it impossible to plug the modules into a standard breadboard with 2.54mm spacing.
What makes it special ?
All sensor module pins are broken out to the PCB Breakout Board which can then be mounted on a standard breadboard with 2.54mm spacing. This allows quick and easy prototyping.
The PCB Breakout Board provides serial (UART) and analog (DAC) interfaces to the sensor module to allow accurate measurements of atmospheric volume of carbon monoxide concentrations from 0ppm - 500ppm.
How to program ?
Arduino libraries are available to download for the ZE07-CO sensor modules although these are not strictly necessary if using the DAC analog pinout. Using the DAC pinout for measurements is much simplier as only three connections are needed to get the sensor module working - 5.0v supply, Ground and Analog Out. Furthermore, the Winsen sensor modules are calibrated for changes in temperature.
What you get:
5 x PCB Breakout Boards.
5 x 15 pin single 2.54mm header strips.
PCB Color: Green
Please note the following:
The ZE07-CO / ZE15-C0 sensor modules are NOT supplied.
These are NOT official or licensed Winsen products.
The PCB Breakout Boards will be shipped from France by French Standard Mail, tracking not included.
Links:
Arduino Libraries on Github:
Tweenie Tomatoes ZE07-CO Library
There's also an interesting article on the use of Winsen Carbon Monoxide sensor modules to be found here:
Enter your email address if you'd like to be notified when PCB Breakout Boards for Winsen ZE07-CO Modules can be shipped to you:
Shipping normally within 3-5 business days.
1-4 | $20.00 |
5-9 | $18.50 |
10-19 | $17.00 |
20+ | $15.00 |
$16.99
$1.25
$7.64 $8.99
