+12/-12 Eurorack power supply with 6 breakouts + small bus board as a gift.
Designed by GDNR synth in Latvia
What is it? Generic Eurorack power supply board. Needs 12V~16V AC adapter. Has 6x 4700uF capacitors and 2x 100uF for smooth operating. Note it has only +12/-12V breakout with 10 pin Eurorack bus conn…
Read More…Generic Eurorack power supply board. Needs 12V~16V AC adapter. Has 6x 4700uF capacitors and 2x 100uF for smooth operating. Note it has only +12/-12V breakout with 10 pin Eurorack bus connector. Safely operates up to 1000mA. Has holes for a screw terminal if you are into that sort of things.
As a bonus you get a small 10 pin bus board!
Really nice looking design. And has tons of capacitors to make the supply really smooth.
Enter your email address if you'd like to be notified when Eurorack power supply can be shipped to you:
$168.00
$46.00
$32.99
