NEW: added rev.B. Same functionality of rev.A but added Micro USB connector to power the board: Rev. A can be powered by ICSP connector and by V+ Pin (max 13,2V); Rev. B can be powered by ICSP …
Read More…NEW: added rev.B. Same functionality of rev.A but added Micro USB connector to power the board:
Rev. B can be powered by ICSP connector, by USB connector and by V+ Pin (max 13,2V).
Z1 Mini is a development board based on cc2530 chip (Ebyte module). With this board and a configurable firmware, it is possible to build various custom zigbee end devices (switches, buttons, relays, temperature, humidity, gas, co2, energy meter, three-phase meter, ADC, PWM, modbus and various combinations of them). The board can use standard cc2530 (4dBm module E18-MS1-PCB) or amplified cc2530 type (20dBm module E18-MS1PA2-PCB). It is provided with standard ICSP connector; the firmware can be flashed using CC-debugger, SmartRF04EB or a Raspberry used as programmer. Created devices are all supported in zigbee2mqtt and Homeassistant and works also as zigbee router.
So you can finally build your own zigbee devices with the same or even more simplicity you had with Tasmota or Esphome so far! You can combine multiple sensors, switches, relays etc. on only one zigbee board. You can free your wifi network by using custom zigbee devices for your smart home.
This small board was especially designed to easily build custom zigbee devices as never before, with a large number of IO, plus UART, I2C, ADC and PWM. It is sold fully assembled and tested.
Enter your email address if you'd like to be notified when Z1-Mini can be shipped to you:
Ada | July 1, 2022
Gustaf | Oct. 7, 2021
$13.80
$17.90
