ESP32 based telemetry radio that enables plug-and-play communication between a Pixhawk based flight controller and a ground station via Wifi
Designed by Goose's Tech in New Zealand
ESP32 TELEMETRY RADIO This board is a Wifi telemetry radio based on an ESP32-C3. It allows communication between a Pixhawk flight controller and a ground station (such as QGroundControl) in a simple …
Read More…This board is a Wifi telemetry radio based on an ESP32-C3. It allows communication between a Pixhawk flight controller and a ground station (such as QGroundControl) in a simple and lightweight package.
The board is designed to plug straight into an available telemetry port on your Pixhawk flight controller, with no soldering required. Simply take a 6-wire JST-GH cable (that comes with Pixhawk flight controllers) and connect the board to the flight controller.
The ESP32 runs DroneBridge for ESP32 software, which enables the link between the vehicle and the ground station. This comes pre-flashed on the board so that the only configuration that is required is on the flight controller.
Enter your email address if you'd like to be notified when ESP32-C3 Telemetry Radio For Pixhawk UAVs can be shipped to you:
