Great RF spectrum analyzer to measure signals up to the GHz range, 100kHz to 1.7GHz
Sold By H-Instruments
The spectrum analyzer with the SDR software features: Frequency range from 100 KHz to 1.7 GHz Demodulation: AM, FM (NBFM, WBFM), CW, DSB, SSB (LSB / USB) SMA connectors for professional use High Qual…
Read More…Frequency range from 100 KHz to 1.7 GHz Demodulation: AM, FM (NBFM, WBFM), CW, DSB, SSB (LSB / USB) SMA connectors for professional use High Quality aluminum casing and SMA connectors Broad array of RF related applications:
Make relative measurements on antenna to find gain Compare the gain of one antenna to another Make relative measurements on transmitted power Check if the transmitter is transmitting, like car key, VHF, CB etc. See what signals are in the air and demodulated them Listen to radio communication EMI testing And much more We send you a link to the spectrum analyzer software as soon as you have placed your order.
R820T+RTL2832U chip; Support SDR; Support DAB; Support FM; Support DVB-T;
Support Windows 2000/XP/Vista/WIN7 & Win10 Support both MPEG-2, MPEG-4(H.264) encoding;
1xUSB spectrum analyzer SDR 1xAntenna 1xUSB cable
Cheap and easy to use
Enter your email address if you'd like to be notified when RS-20 RF Spectrum Analyzer 100KHz to 1760MHz USB can be shipped to you:
Product: (4.00)
Documentation: (3.00)
Richard | May 5, 2023
$238.00
$179.00
$139.00
$129.00
$195.00
$149.00
$338.00
$89.00
$377.83
$163.90
$2088.00
