HS-100 is a handheld easy to use simulator for PT100 or PT1000 0.3850 platinum resistance elements (RTD) used for temperature measurements.
Designed by H-Instruments in Iceland
HS-100 is a handheld easy to use simulator for PT100 or PT1000 0.3850 platinum resistance elements (RTD) used for temperature measurements. 12 fixed output settings in °C: -25°C, 0°C, 25°C, 50°C, 75°…
Read More…HS-100 is a handheld easy to use simulator for PT100 or PT1000 0.3850 platinum resistance elements (RTD) used for temperature measurements.
12 fixed output settings in °C: -25°C, 0°C, 25°C, 50°C, 75°C, 100°C, 150°C, 200°C, 250°C, 300°C, 400°C & 500°C. OR 12 fixed output settings in °F: -10°F, 32°F, 80°F, 120°F, 150°F, 200°F, 300°F, 400°F, 500°F, 600°F, 750°F & 900°F.
Please use the drop down menu to select the version you need, PT-100 °C, PT-100°F, PT-1000°C or PT-1000°F
Applications:
Checking temperature meters and measuring systems. Helping maintenance personnel and integrators in RTD analog input testing, troubleshooting and application development. Temporarily replace and simulate a 2-wire, 3-wire or 4-wire Platinum 100 Ohm 385RTD resistor Since the output from HS-100 is purely passive resistance it will operate with all types of PT100 measuring instruments. -
Easy to use:
Connect your PT-100 input to the two terminals
Use the switch to select the temperature you need to check. No power needed -
Specifications:
Accuracy typical +- 1% or +- 1°C (+-1.2°F) whatever is bigger. HS-100 is not a calibrator, but are intended to verify in a easy way the function of meters, control systems etc. NEW Compact model! size(84x54x30mm) makes it ideal for lab or field use. CE compliant 1 year warranty
Enter your email address if you'd like to be notified when RTD simulator / calibrator & tester in °C or °F PT can be shipped to you:
$238.00
$179.00
$129.00
$195.00
$149.00
$338.00
$89.00
$169.00
$10000.00
$150.00
$14.99
