Looking for no frills multi system emulator that fits in your pocket? Look no further! This is it, Game Boy Zero - Handheld Edition!!!
Designed by Handheld Gaming in CanadaThis product is no longer available for sale.
LAST FEW IN STOCK Here's the deal PRICE DROP No more USB Sound cards to give out No more Plexi Cases No pretty cardboard box $5 OFF If you buy 2, you get them both for $80 Game Boy Zero Looking…
Read More…Here's the deal
Looking for a no frills multi system emulator that fits in your pocket? Look no further! This is it, Gameboy Zero - Handheld Edition!!!
The Game Boy Zero - Handheld Edition 2.0 is an all in one solution for playing your favorite retro, classic games Design around a Raspberry Pi Zero, you can play up to and including PlayStation 1 games.
Two board in one kit!
It's a multi part PCB, which allows you to place a bigger battery in between the boards. The front board can be run independently (without the back board) if you don't need shoulder and trigger buttons for you games
Both PCBs are fully populated and assembled.
Custom ready to go image
Download and run our custom RetroPie image
This image comes with the Super Famicom Controller Test Program
Raspberry Pi Zero based arcade in you pocket
The boards have been tested with the following platforms:
Other platforms are yet to be tested.
If you do not plan on using the provided Raspberry Pi image, simply download the latest RetroPie pre made image for the Raspberry Pi Zero
Once you have installed RetroPie onto your SD card and mounted it on your Pi follow along with the Installation Instructions document provided
Official Releases GitHub Release
If you are planning to mount your own image on an SD Card, this one is prebuilt for the Game Boy Zero - Handheld Edition from KickStarter
Baked in support for
What to do, and how to do it
The layered plexi case is a 4 piece kit. Easy to assemble
Image | Description |
This one is optional and requires removal of the glass on the TFT (see Full Assembly section of the wiki) the glass cover on the TFT should be protection enough for casual play |
This is where you place the top shim and the dpad |
Top PCB | The PCB with the screen |
Bottom PCB | The PCB with only buttons |
This is the bottom plexi layer |
1 | $45.00 |
2+ | $40.00 |
Product: (4.64)
Documentation: (4.27)
Shipping: (4.55)
Communication: (4.18)
Shawn | May 23, 2018
Greg | May 23, 2018
Danmeng | May 21, 2018
Jose Luis | May 16, 2018
Alex | May 13, 2018
Jacob | April 25, 2018
John | April 12, 2018
Charles | April 7, 2018
Eric | March 26, 2018
Richard | March 21, 2018
Emmanuel | March 2, 2018
$139.00
$89.99
