A repair kit for your Amiga 1200's broken rear case clips!
Designed by Hey Birt! in United States of America
After coming out with the Case Saver kits for the C64 bread bin and 64C we started getting requests for a similar kit for the Amiga 600. The popularity of the A600 Case Saver Kit then led to the Amig…
Read More…After coming out with the Case Saver kits for the C64 bread bin and 64C we started getting requests for a similar kit for the Amiga 600. The popularity of the A600 Case Saver Kit then led to the Amiga A1200 kit. The A1200 rear clips are similar to the A600 consisting to two 'hooks' that are quite easily broken, but of course they are slightly different in size and shape than the A600.
The replacement back clips are made to slip in between the two original 'hooks' and can be used to repair broken clips or to bolster intact clips to keep them from breaking off in the future. The arch of the clip is very close to the original while keeping it as thick as possible for added strength. The 'wings' on the rear of the repair clip register against the original hooks to help align then and keep them in the proper place while the epoxy cures.
While the 'wings' make the clips stronger and easier to install they do interfere with floppy drives. We include a full set of 5 clips 'with wings' which will work fine if you are using a Gotek or something similar instead of a floppy drive. We are also including two rear clips without 'wings' for the right hand side two clips by the floppy drive in case you still have your floppy drive.
Each kit contains five of the rear repair kits with 'wings', and two rear clips with no 'wings'.
Enter your email address if you'd like to be notified when Amiga 1200 Case Saver Kit can be shipped to you:
$12.95
$6.95
$6.50
$8.85
$2.60
