A repair kit for your Amiga 600's broken case clips!
Designed by Hey Birt! in United States of America
After coming out with the Case Saver kits for the C64 bread bin and 64C we started getting requests for a similar kit for the Amiga 600. The A600 uses similar 'hooks' as the VIC20 and early C64 bread…
Read More…After coming out with the Case Saver kits for the C64 bread bin and 64C we started getting requests for a similar kit for the Amiga 600. The A600 uses similar 'hooks' as the VIC20 and early C64 bread bins but scaled down considerably. In addition to four back clips there are two clips on the side.
The back clips are made to slip in between the two original 'hooks' and can be used to repair broken clips or to bolster intact clips to keep them from breaking off in the future. The arch of the clip is very close to the original while keeping it as thick as possible for added strength. The 'wings' on the rear of the repair clip register against the original hooks to help align then and keep them in the proper place while the epoxy cures.
We found out after releasing this kit that the 'wings' added to the rear clips can interfere some floppy drives. Now we are also including two rear clips without 'wings' for the right hand side two clips by the floppy drive in case you have a tight fit there.
The side clips were tricky to make as there is not a lot of room to work with and we wanted them to also hold themselves into place while the epoxy cures. These repair clips are made to set over a broken clip that is filed flush, so there is a left and right hand side slip. The tip of the hook tapers down to the dimensions of the original clip while being stronger.
Each kit contains four of the rear repair kits with 'wings', two rear clips with no 'wings', and once each of the left and right side repair clips.
Enter your email address if you'd like to be notified when Amiga 600 Case Saver Kit can be shipped to you:
$12.95
$6.50
$6.95
$8.85
$2.60
$69.99
$49.95
