This is a tiny USB-MIDI OUT interface. The MIDI OUT is TRS (3.5mm stereo jack) type.
Designed by Hiro Akihabara's shop in Vietnam
This is tiny USB-MIDI (OUT) interface. It's convenient when you connect your MIDI device such as sampler or synthesizer to PC, and play their sounds triggering with your softwares on your PC. There …
Read More…This is tiny USB-MIDI (OUT) interface.
There is USB type C connector on the one side of the product, and MIDI OUT (TRS, 3.5mm stereo) jack on the other side of the product. It has blue LED indicator which brinks when MIDI signal is sent from USB port of PC. Connect the USB connector to your PC's USB port and connect the MIDI (TRS) jack to your MIDI device with normal 3.5mm stereo cable for audio.
The module is very tiny so that it doesn't take much space of your desk. It is compatible with Windows standard drivers, so you don't have to struggle to install drivers by yourself. At the first time you connect it to your PC, it will be installed to the PC automatically.
Enter your email address if you'd like to be notified when USB-MIDI (TRS) Interface can be shipped to you:
