This board replaces your old Honeywell or DSC alarm panel board , and operates with ESPHome
Designed by Home Control Labs in United States of AmericaThis product is no longer available for sale.
What is it? A replacement board for a Honeywell or DSC alarm panel which allows you to use wired alarm sensors as binary sensors in ESPHome and HomeAssistant. Why did you make it? I had a Honeywell a…
Read More…A replacement board for a Honeywell or DSC alarm panel which allows you to use wired alarm sensors as binary sensors in ESPHome and HomeAssistant.
I had a Honeywell alarm panel and an Eyez-on envisalink to interface with HomeAssistant, but it depended on the cloud, and the Honeywell panel didn't transmit information to the Eyez-on board when a sensor was restored to the non-faulted state. I designed this board to completely replace a Honeywell Vista 20 alarm panel except the following feature:
The board is completely assembled except for the two tact switches used for EN and BOOT. These will need to be soldered onto the board in order to upload the ESPHome firmware. The reason for shipping the board without these 2 switches is to avoid having to do a costly FCC certification which doesn't make much sense for a low volume product used by Home Automation enthusiasts.
You'll need some technical knowledge use this effectively. It will require some firmware programming and electrical knowledge to successfully implement. One should have some experience modifying ESPHome yaml files, reading wiring diagrams, using a Windows or Linux command line shell, using serial devices such as the FTDI serial cable, and using the ESPHome tool to program ESPHome devices. If you are not sure how to program firmware into an ESPHome device, please study the documentation on esphome.com and become familiar with it before purchasing a board. Programming documentation can be found in the WIKI.
By purchasing and/or using this sensor panel hardware, you indicate you agree that are using it at your own risk.
You also agree that I will not be held liable for hardware failure, fire, injury, death, theft, property damage or any other loss.
Professional monitoring is not available for this product from me, and this is something you will need to consider when using this hardware.
Since the hardware is shipped in kit form and you will be modifying the software, you will be solely responsible for determining if this hardware and software is fit for purpose.
Non-commercial, residential use only. This product is not intended to be used as life safety device.
La Mesa, CA, United States of America
2 Reviews | 15 Orders
$39.95
