A WIFI 9 Valve Sprinkler Controller based on an ESP32 for use with ESPHome
Designed by Home Control Labs in United States of AmericaThis product is no longer available for sale.
$13.48
$29.99 $39.99
What is it? A 9 Valve sprinkler controller kit designed specifically to work with ESPHome. Comes with the Case, graphic overlay, and the PCB. Why did you make it? To replace an existing sprinkler con…
Read More…A 9 Valve sprinkler controller kit designed specifically to work with ESPHome. Comes with the Case, graphic overlay, and the PCB.
To replace an existing sprinkler controller which was not capable of working with ESPHome.
Because FCC certification is too expensive to undertake for a low volume device such as this, the product is shipped as a tested kit where the EN and BOOT pushbutton switches are supplied but not soldered onto the board. In order to program the device with your customized ESPHOME firmware, the EN and BOOT switches will need to be soldered to the board so that the ESP32 can be placed in upload mode.
Ambrose | April 16, 2024
Jonathan | July 9, 2023
La Mesa, CA, United States of America
2 Reviews | 15 Orders
