This is the board blank for my ESP12-appliance_mod project
Designed by Home Control Labs in United States of AmericaThis product is no longer available for sale.
This is a WIFI-controlled latching relay board blank for use with ESP12 WIFI modules. It can be used to control AC loads remotely using the MQTT protocol. It self-contained and has provisions to moun…
Read More…This is a WIFI-controlled latching relay board blank for use with ESP12 WIFI modules.
It self-contained and has provisions to mount a 5V 1 amp AC power supply over the relay.
The smallest parts used are 0603 surface mount components. Requires a 3.3V FTDI cable for programming.
This board uses mains voltages. Do not attempt to build this unless you know what you are doing with AC line voltages. You build this at your own risk.
La Mesa, CA, United States of America
2 Reviews | 15 Orders
