Making it easy to connect analog signals to your Arduino AND fit in a 3D printed case.
Designed by I-make-robots in Canada
What is it? A PCB that makes it neat and tidy to connect up to six 3-wire connections - from, say, analog inputs - to the analog pins on your Arduino UNO compatible boards. Can be soldered so that i…
Read More…A PCB that makes it neat and tidy to connect up to six 3-wire connections - from, say, analog inputs - to the analog pins on your Arduino UNO compatible boards. Can be soldered so that it hangs off the side of your Arduino for easy and elegant case design.
When I designed the Sixi Joystick I needed six analog input connections to an Arduino. Normally that would mean a breadboard and a mess of wires, or a PCB shield that covers the whole top of the Arduino and leaves wires sticking straight up. I didn't like any of that.
We use it in a real joystick solving real problems.
Make sure to solder the right angle pins LAST.
Enter your email address if you'd like to be notified when Sixi Joystick PCB can be shipped to you:
