The FMC LPC Breakout board is a passive adapter for accessing all signals of ANSI/VITA 57.1 FPGA Mezzanine Cards (FMC).
Features ANSI/VITA 57.1 compliant Commercial grade form factor Low-pin count (LPC) connectors Breakout of carrier card connector Breakout of mezzanine card connector Stackable assembly …
Read More…Features
Stackable assembly
Separate breakout of power pins
Breakout pads with 1.27 mm pitch
Prototyping area with 2.54 mm grid
Open-source hardware
Applications
Easy prototyping
Testing and debugging of FMC modules
Research and education with FPGAs
Description
The FMC LPC Breakout board is a passive adapter for accessing all signals of ANSI/VITA 57.1 FPGA Mezzanine Card (FMC) Standard compliant low-pin-count (LPC) connectors. All pins of the connector's rows C, D, G, and H are routed to a separate pad array on the top and bottom side. These pads were placed at a 1.27 mm pitch to easily attach additional probes or solder wires. For special measuring tasks or for use as a stand-alone carrier, the power pins of the connector were routed to additional vias in the back of the module. Furthermore, simple electrical circuits can be realized on the prototyping area, which is a field of non connected vias with a pitch of 2.54 mm. The FPGA mezzanine card has commercial grade form factor (single width, 78.80 mm x 69 mm) and is designed for air cooling.
The full datasheet is available at https://fmchub.github.io/projects/FMC_LPC_BREAKOUT/Datasheet/FMC_LPC_BREAKOUT_datasheet.html.
Enter your email address if you'd like to be notified when FPGA Mezzanine Card (FMC) Breakout Board can be shipped to you:
1 | $155.00 |
2-3 | $139.50 |
4-5 | $131.75 |
6-7 | $124.00 |
8+ | $116.25 |
Bryan | Nov. 8, 2021
Joe | July 27, 2020
$245.00
$159.00
$249.00
$249.00
$205.00
$235.00
$229.00
$159.00
$4.90
$4.90
$4.90
$205.00
