The board is a powerful programming tool for ANSI/VITA 57.1 FMC EEPROMs (FRU information records).
Features Easy FMC FRU EEPROM programming and readout In-circuit configuration of FRU records Supports I2C EEPROMs with 1 byte and 2 byte addressing Fully open-source product USB serial port…
Read More…Features
USB serial port device
USB powered 3P3VAUX voltage rail
External power supply for 12 V and 3.3 V voltage rails
Write enable/protection output
Selectable GA[1:0] addressing pins
Selectable PG_C2M flag
AVR ISP programming header
Applications
Small batch FMC module programming
Compliance and production tests
Professional production of FMC boards
Prototyping of FMC modules
Applications
The FMC FRU EEPROM Programmer and the related toolchain is a powerful programming tool for FMC FRU (Field Replacable Unit) records. The programming adapter is designed for in-circuit configuration of ANSI/VITA 57.1 FPGA Mezzanine Cards (FMC) according to the IPMI Platform Management FRU Information Storage Definition. The board runs with open-source firmware and software for user-friendly configuration of I2C-compatible serial EEPROMs. Its microcontroller (Microchip ATmega32U4) translates a user command protocol from the serial interface into corresponding I2C read/write accesses to any compatible EEPROM devices. A user application on the PC host simplifies file transfers to the EEPROM via a USB cable. By eliminating the need for customer-specific FPGA firmware to program an FMC module, the standalone programming adapter is suitable for reliable small-batch production and prototyping.
The full datasheet is available at https://fmchub.github.io/projects/.../FMC_FRU_EEPROM_PROGRAMMER_datasheet.html.
Enter your email address if you'd like to be notified when FPGA Mezzanine Card (FMC) FRU EEPROM Programmer can be shipped to you:
$155.00
$159.00
$249.00
$249.00
$205.00
$235.00
$229.00
$159.00
