The board is the most straightforward solution for board-to-board connections, signal generation and debugging with the FMC connector.
Features Low-pin count (LPC) connector Handy breakout for FMC carriers Pin headers with 2.54 mm pitch SMA connectors for high-speed data (multi gigabit transceivers) SMA connector for dedic…
Read More…Features
SMA connector for dedicated clock IO
EEPROM for FRU information storage
Small form factor
Open-source hardware
Applications
Easy prototyping
Logic Analyzer
Clock Synthesizer
Trigger-Generator
Pattern-Generator
Board-to-Board interconnections
Debugging and test of digital designs
Research and education with FPGAs
Description
The FMC pin header board was developed to make the high density FMC connector of many FPGA boards easily accessible. In many applications easily pluggable connections are required to process and check the digital signals. The use of 2.54 mm pin headers is very common. Thus, the FMC pin header board enables a variety of applications for digital signal processing and testing. The total number of 68 user signals (LAxx_P/N), 4 user clocks (CLKx_M2C_P/N) and 3 voltage rails (VADJ, 3P3V and 12PV0) from the carrier card connector are routed to the 2.54 mm pin grid on top of the adapter board. In addition, the high-speed data lanes (multi-gigabit transceivers) are easily accessible via SMA connectors on the edge of the PCB. Finally, the board allows complete interconnection of all signals from the FMC connector.
The full datasheet is available at https://fmchub.github.io/projects/FMC_LPC_PINHEADER/Datasheet/FMC_LPC_PINHEADER_datasheet.html.
Enter your email address if you'd like to be notified when FPGA Mezzanine Card (FMC) LPC Pin Header Board can be shipped to you:
1 | $235.00 |
2-3 | $202.50 |
4-5 | $191.25 |
6-7 | $180.00 |
8+ | $168.75 |
$155.00
$245.00
$159.00
$249.00
$249.00
$205.00
$229.00
$159.00
$205.00
$159.00
