The FMC power Module provides easy access and manipulation of all power rails and flags defined by ANSI/VITA 57.1 standard.
Features HPC interconnector for the breakout and supply of all power signals Forwarding of all FMC High-Pin Count signals Allows external supply of all FMC voltage rails Selectable voltage su…
Read More…Features
Selectable voltage supply via the carrier board or external source
Connections for measuring current loads on all rails
Manipulating FMC control flags between carrier and mezzanine card
Determination of the load behaviour under different conditions
Open-source hardware
Applications
Electrical characterization of FMC modules
Analysis of current consumption
Compliance and production tests
Easy prototyping and debugging
Description
The FMC Power Module is designed to provide external power to FPGA mezzanine cards (FMC) under test. Often the FMC carrier board does not have the capabilities to monitor and manipulate the FMC voltage rails (12.0V, 3.3V, VADJ and 3.3V AUX) individually. For testing an FMC card, it is convenient to feed the voltages through an external power supply. This allows the voltage levels and current consumption to be closely monitored and verified. Such analysis is required for each FMC module because all power requirements must be stored in the EEPROM of the Field Replaceable Unit (FRU) on the mezzanine card. The supply of external voltages is useful for a variety of Unit-Under-Test applications.
Enter your email address if you'd like to be notified when FPGA Mezzanine Card (FMC) Power Module can be shipped to you:
1 | $229.00 |
2-3 | $206.10 |
4+ | $194.65 |
$155.00
$245.00
$159.00
$249.00
$249.00
$205.00
$235.00
$159.00
$189.00
$34.95
$199.00
