The FMC SFP Adapter is a passive adapter for accessing the multi-gigabit transceiver data pair of the FMC low-pin count (LPC) connector
Features Breakout of SFP connector Data rates up to 4 Gb/s ANSI/VITA 57.1 compliant Commercial grade form factor Low-pin count (LPC) connector Selectable I2C bus voltage (VADJ or 3P3V) …
Read More…Features
Open-source hardware
Applications
1000BASE-X data links
Board-to-board connections
Testing and debugging of SFP transceivers
Easy prototyping
Loopback testing
Research and education with FPGAs
Description
The FMC SFP Adapter Board is a passive adapter for accessing the multi-gigabit transceiver data pair of the FMC low-pin count (LPC) connector. The DP0_C2M and DP0_M2C data pairs are connected to the 20-pin SFP board connector inside the single-port SFP cage. The board supports data rates up to 4 Gb/s, and is ideally suited for 1000BASE-X applications (Gigabit Ethernet transmission over fiber). An on-board oscillators provides a reference clock of 125.000 MHz to the GBTCLK signal pair (clock signal for multi-gigabit transceiver data pair). All electrical signals of the SFP transceiver are accessible via the FMC-LPC connector or test points on the PCB. No configuration of the card is necessary for easy startup.
Enter your email address if you'd like to be notified when FPGA Mezzanine Card (FMC) SFP Adapter Board can be shipped to you:
1 | $159.00 |
2-3 | $143.10 |
4-5 | $135.15 |
6-7 | $127.20 |
8+ | $119.25 |
$155.00
$245.00
$159.00
$249.00
$249.00
$205.00
$235.00
$229.00
