Lightweight but powerful carrier board for the Raspberry Pi Zero 2 W - Powerful DCDC Converter | CAN-Toolhead Interface | lots of GPIO
Designed by IB-Wistinghausen in Germany
Small form-factor carrier board for the all new Raspberry Pi Zero 2 W. As the newest member of the Pi Zero family is now finally powerful enough to run a sophisticated 3D-Printer setup with Klipper I…
Read More…Small form-factor carrier board for the all new Raspberry Pi Zero 2 W. As the newest member of the Pi Zero family is now finally powerful enough to run a sophisticated 3D-Printer setup with Klipper I decided to design a small carrier board to make integration in the printer as easy as possible. The board features a 5V 5A DCDC-Converter providing power to the pi and allowing you to feed it directly from the powersupply of your printer. Also included are dedicated headers for I2C and UART communication as well as a dedicated header to connect an ADXL345 to you pi for resonance calibration. Following the trend of CAN-Bus based toolhead boards the ZeroPointModule has an integrated CAN interface connected to the Raspberry Pi via SPI. To push the usefulness to the max, I also integrated two 3A MosFET channels, a rgb led and broke out all unused GPIOs to pinheaders.
Enter your email address if you'd like to be notified when ZeroPointModule a Zero 2 W carrier for 3D printing can be shipped to you:
$4.95
$41.99
$8.95
