Batteryless energy pack for small projects that needs discontinues power for measurements etc.
Designed by EMT in Canada
What is it? This is the first attempt at a non-battery IOT node, it uses a 2x3cm solar panel connected to the energy harvesting IC, charging a super capacitor and on the output is a 3.3V buck boost c…
Read More…This is the first attempt at a non-battery IOT node, it uses a 2x3cm solar panel connected to the energy harvesting IC, charging a super capacitor and on the output is a 3.3V buck boost converter that turns every drop of energy into a regulated 3v3 voltage for use in projects that needs a renewable source
The worked of IoT is expanding and the next logic step is to work on getting rid of the battery and work purely on sustainable means, this is a proof of concept to see if it can generate enough power to run a practical application, such as environmental sensors and sending the data via Lorawan to a remote gateway.
It freaking Works! with a 1F supercapacitor, I'm able to put this device outside and within 5 min of the sun hitting it, the super cap has charged enough to turn on the output and provide a constant 3v3 while the super cap charges to its max capacity.
The devices uses a LTC3105 energy harvester with a MAX77827 buck boost converter and a 1F 3.9V super capacitor
Enter your email address if you'd like to be notified when SOLAR BUDDY( Battery less energy harvesting pack ) can be shipped to you:
