R.F H.F Dummy Load
Designed by JasonKits QRP in MaltaThis seller is taking a break until Dec. 29, 2025. Sign up below to get an email when they're back!
The dummy Load uses 20 1Kilo-Ohm 3 watt non-inductive resistors in parallel to achieve 50 Ohms over a wide frequency range. It is submerged in oil to allow somewhat extended operation during tuning …
Read More…The dummy Load uses 20 1Kilo-Ohm 3 watt non-inductive resistors in parallel to achieve 50 Ohms over a wide frequency range. It is submerged in oil to allow somewhat extended operation during tuning or repair procedures. The advantages are:
(1) It's cheap, only 2 PCB's act as the connection
(2) It provides a very pure 50 Ohm resistance load through 30 MHz and beyond,
(3) You can easily add power measurement and rig testing capability.(PCB has a place to install on board a diode and a capacitor )
This one is conservatively designed for rigs that have power output levels up to 100 watt. I built it into a one-quart paint can, readily available at Ace Hardware for about 89 cents.
Supplied pcbs can be easily assembled with readily available resistors carbon film ..
What is Included
2 x PCB'S ( No Resistors Included )
Enter your email address if you'd like to be notified when 100Watt Dummy Load (20xResistors Array) can be shipped to you:
$59.00
$69.98
$53.00
$140.00
$27.00
