Sequential Low Pass Filter
What is it? The 4 channel low pass filter was designed to be used after a PA Linear Amplifier to suppress the harmonics. The key features include a sequential switch which toggles/hops from one filte…
Read More…The 4 channel low pass filter was designed to be used after a PA Linear Amplifier to suppress the harmonics. The key features include a sequential switch which toggles/hops from one filter to another in order to toggle the correct filter for the band.
The Board requires a 12volt supply to power the board and switch the relays accordingly. An optional connector is also included in case the board needs to be connected via a microprocessor or switching circuit.
The board was made to interface with the H.F Linear Amp, and after building the filters can be used without any calibration.
Easy to connect
Switches four low pass filter and is user configurable. 20M - 30M - 17M - 10M
Push Button control to hop the bands
Requires 12v input to power the board
Led indication
BNC Sockets for input and output
What is Included ? Bare PCB with Instructions
Enter your email address if you'd like to be notified when 4 channel Sequential Low Pass Filter can be shipped to you:
$69.98
$53.00
$99.99
$56.99
$39.50
