DIY RADIO 40M CW Shortwave Transmitter QRP Pixie Kit Receiver 7.023-7.026MHz
Sold By JasonKits QRP
The Pixie radio is a very simple 1/2-watt 40-meter CW transmitter/receiver. The 40m Pixie is a simple CW transceiver. A QRP crystal-controlled with a basic "key" input and minimal components. An Amat…
Read More…The Pixie radio is a very simple 1/2-watt 40-meter CW transmitter/receiver.
The 40m Pixie is a simple CW transceiver. A QRP crystal-controlled with a basic "key" input and minimal components. An Amateur Radio license is required to use this kit and to transmit with it. Once built, it has a fixed transmit frequency of 7.023MHz and the RX can be shifted a few hundred Hz using the variable pot.
7.023MHz crystal supplied
BNC aerial connector
Straight Key input
800mW to 1-watt 9-12v DC
LM386 audio amp for headphones or small 8-ohm speaker
QRP Power: 1.2W with a 40M antenna SWR <2.00
Supplied as a kit.
Enter your email address if you'd like to be notified when 40M CW TRX QRP Pixie Kit 7.023-7.026MHz can be shipped to you:
$69.98
$53.00
