Acknowledgement: All credits for the PCB design by RSZ. What is it? The module was designed to be added to the ESP32 SI473X radios and can also be used together with an Arduino hooked to a lcd screen…
Read More…Acknowledgement: All credits for the PCB design by RSZ.
The module was designed to be added to the ESP32 SI473X radios and can also be used together with an Arduino hooked to a lcd screen or else to a serial terminal.
The module features a PLL which can be adjusted its center frequency to decode through software digital modes such as CW RTTY etc.
I have built the ESP32 SI473x radio and upgraded the software to v 4.16 AIR which features a digital decoder. This hardware module is needed to decode such modes.
PCB only is included - schematic is available on request.
Enter your email address if you'd like to be notified when ATS25 CW-Decoder Module for ESP32 -SI473X Radio can be shipped to you:
Terry | April 3, 2024
Unyatinszki | Nov. 28, 2023
$69.98
$53.00
