Frequency Counter
Sold By JasonKits QRP
Acknowledgement : Credits to Wolfgang Buescher, DL4YHF for designing this project.(based on a work by James Hutchby, MadLab, 1996) What is it? The frequency counter kit can be used to measure freq…
Read More…Acknowledgement : Credits to Wolfgang Buescher, DL4YHF for designing this project.(based on a work by James Hutchby, MadLab, 1996)
The frequency counter kit can be used to measure frequencies from 1hz to 50mhz and also check quartz crystals. The Frequency counter has a onboard button which can access a menu to zero the scale, add or deduct an offset in case it will be used in a shortwave receiver.
The pcb is well labelled and makes it very easy to assemble it.
Features : · frequency range 1 Hz ... 50 MHz
· five digits resolution (display for example x.xxxx kHz, x.xxxx MHz, or xx.xxx MHz)
· automatic range switching with different gate times
· optional addition or subtraction of a frequency offset (programmable)
· optional preamplifier for the input signal
· very low component count: a PIC 16F628, 5 7-segment LED displays, a 20-MHz crystal and a few resistors
· optional (configurable) power-saving mode which automatically turns the display off if the frequency didn't change significantly within 15 seconds
Supplied as a Kit (You Need to solder the components on the board yourself)
Enter your email address if you'd like to be notified when Classic Frequency Counter 1Hz-50Mhz can be shipped to you:
$69.98
$53.00
