Mini Whip Antenna for MW. LW SW
Sold By JasonKits QRP
What is it? The original PA0RDT Mini Whip is a very simple and effective active receive antenna for the longwave, medium wave and shortwave range. It consists of a small metal plate and a buffer ampl…
Read More…The original PA0RDT Mini Whip is a very simple and effective active receive antenna for the longwave, medium wave and shortwave range. It consists of a small metal plate and a buffer amplifier. The amplifier has a very high input impedance (implemented using a JFET as a source follower) to sense the voltage between the metal plate and ground, and a low output impedance (implemented using an NPN transistor as an emitter follower) to drive the 50 ohm coax cable.
To be used for Radio Reception
Frequency range: 10 kHz - 30 MHz
Power: DC 5 - 13 V, 100 mA
RF connector: SMA
Feed line: 50 Ohm coaxial cable
Used PCB Material: FR-4
PCB thickness: 1.6 mm
PCB copper weight: 1 oz
The Main advantage of this antenna is that it very small and can be installed everywhere where space is not available.
Being a powered device it will perform in all conditions and reception is very crisp.
Enter your email address if you'd like to be notified when Mini Whip Antenna can be shipped to you:
$64.98 $69.98
$53.00
$59.00
$31.90
$102.00
