Iambic Morse code Practice Keyer and decoder
Sold By JasonKits QRP
Thanks to Scott Baker who shared this project. All credits goes to him . The Iambic Morse code Keyer and Decoder is a standalone unit which can send morse code by the use of an external keyer or tri…
Read More…Thanks to Scott Baker who shared this project. All credits goes to him .
The Iambic Morse code Keyer and Decoder is a standalone unit which can send morse code by the use of an external keyer or trigger an TRX when sending a stored message. Besides being a morse keyer it can also decode morse paddle input and display it on the oled screen.
It can also send a message and messages can be edited and stored in the internal eeprom.
The unit has a menu system and offers the following features:
Menu Options
Keyer Speed - range 10 to 40 WPM (Words per Minute)
Iambic Selection A/B
Volume Level - three levels 1-2-3
Sidetone - 600hz or 700hz
Key Swap -Select swap of dit and dah paddles
Save Config - Save changes to Eeprom
Send message - Select a pre-recorded message to edit
Edit message - Select a pre-recorded message to edit
Record message - Select a message to record
Assembled Unit .
Enter your email address if you'd like to be notified when Morse Iambic Keyer -Practice Keyer & Morse Decoder can be shipped to you:
$69.98
$53.00
$59.00
$155.95
$160.00
