Nano vna test board
What is it? This board carries most common circuits found in R.F . It consists of a board which can accommodate 18 tests. Why did you make it? I needed such board to test the nano vna capabilities. …
Read More…This board carries most common circuits found in R.F . It consists of a board which can accommodate 18 tests.
I needed such board to test the nano vna capabilities. Also stop from using the connectors that come with nanovna.
The board Hosts the following setup
1: Open Test
2: Sh ort Test
3: Load Test
4: Through Test
5: 33 ohm resistor test
6: 75 ohm resistor test
7: Capacitor test
8: Inductor test
9: -5db attenuator
10: -10db attenuator
11: 30Mhz Low pass Filter
12: 100Mhz High Pass Filter
13: 433Mhz Band Pass Filter
14: 6.5Mhz Band Pass Filter
15: Capacitor Inductor Resistor test
16: Capacitor Resistor Inductor test
17: Capacitor Inductor test
18: Capacitor Resistor test
Supplied as Bare unpopulated PCB with instructions.
Enter your email address if you'd like to be notified when Nano VNA Test Board Demo can be shipped to you:
$69.98
$53.00
