No Tune End Fed Half Wave Antenna, 80m-10m End-fed Half-Wave Linear Antenna 10 Watts Rated Power Antenna Module
Sold By JasonKits QRP
The single band 80 m to 10 m side feed half-wave linear antenna is designed for high portability. The antenna can be configured in various shapes: inverted "V", horizontal, inclined, and vertical (fo…
Read More…The single band 80 m to 10 m side feed half-wave linear antenna is designed for high portability. The antenna can be configured in various shapes: inverted "V", horizontal, inclined, and vertical (for high frequencies). It uses a balanced feed line, eliminating the need for a separate feeder.
A 1:49 toroid transformer is integrated for impedance matching with a 50-ohm feed point, handling up to 10 watts. The kit includes a high-voltage capacitor for reduced SWR across 80 m to 10 m bands, enabling use without a tuner, and optimized for SWR of 1.2 or less across the band.
You can also add some counter poise to improve the SWR.
The impedance: 50 Ohm
Weight: 35 g
Size: 100 * 71 mm
Product weight: 40 g
Enter your email address if you'd like to be notified when No Tune End Fed Half Wave Antenna, 80m-10m 10 Watt can be shipped to you:
$69.98
$53.00
$31.90
$9.50
