QRP Power meter
Designed by JasonKits QRP in MaltaNo shipping info available.
What is it? The QRP power meter can measure R.F power from an ADX TRX or similar low power transmitter. Code has been updated to use the 10 bit resolution of the AVR AtTiny85 MCU. Uses an OLED 0.96" …
Read More…The QRP power meter can measure R.F power from an ADX TRX or similar low power transmitter. Code has been updated to use the 10 bit resolution of the AVR AtTiny85 MCU. Uses an OLED 0.96" 128x64 or 128 x 32 pixel Screen to display the readings. A feature was also included to blank out the oled screen in order to protect the display from over burning.
The QRP power Meter has an onBoard Regulator and D.C filtering.
Dummy load is composed of eight Metal Film 3Watt Resistors.
Specifications:
Max peak power input : 20W
Frequency Range : DC to 30Mhz (H.F)
Dummy load : Metal Film 50 Ohm Air Cooled
RF Input : BNC Module Power In : D.C 12v - Regulated TO 5Volts on Board
Extra Features
Start/Stop Switch : to start a new measurement
Oled screen Blanking to save Oled Display
Enter your email address if you'd like to be notified when QRP Power Meter Attiny85 with Oled can be shipped to you:
$69.98
$53.00
$29.50
$99.99
$87.99
