Quansheng UV-K5 RX H.F Audio Mod
Description The Radio mod chip shown in the picture is not included in this listing - only the audio module RED BOX FPC module will be shipped. This listing is for the Audio Module bottom part whi…
Read More…Description
This listing is for the Audio Module bottom part which requires installation in the Quansheng UV-K5 TRX . It has been developed to enhance the audio quality in USB/LSB/CW modes. While AM and FM modes exhibit good audio, it was observed that audio levels were somewhat low in side-band modes.
Purpose
The creation of this mod stemmed from the need to address the audio quality disparity between different modes. To tackle this issue, an audio pre-amp with a gain of 50-100 was devised. Once integrated, this pre-amp offers the necessary audio boost for side-band modes.
Unique Features
Designed to be compatible with the existing FPC SI4732 setup
Piggybacks on the same chip pinout, utilizing the same supply and audio pins
Requires only one wire to be soldered to a specific point for installation
What is Included
Assembled Audio preamp fpc board for manual installation Service to install module with send - back to customer..
Enter your email address if you'd like to be notified when Quansheng UV-K5 TRX H.F Audio Mod Service can be shipped to you:
$69.98
$53.00
$15.99
$28.90
$6.99
