SI5351A Arduino Signal Generator with Sweep Function.
Designed by JasonKits QRP in MaltaThis seller is taking a break until Dec. 29, 2025. Sign up below to get an email when they're back!
What is it? This board features an AVR ATMega328 and Silicon Labs Si5351A-B-GT LVCMOS Clock Generator which supports 3 outputs and has a frequency output between 0.0025 and 220 Mhz. The ports can be…
Read More…This board features an AVR ATMega328 and Silicon Labs Si5351A-B-GT LVCMOS Clock Generator which supports 3 outputs and has a frequency output between 0.0025 and 220 Mhz. The ports can be individually programmed for frequency (100 kHz to 225 Mhz), sweep width, and output power control - 2ma - 4ma - 8ma.
I needed a variable clock source to test some filters and my signal generator was limited to H.F. Frequencies. So I designed this board to handle higher frequencies. I used a RC filter to convert the signal to a sine wave.
The board features :
Assembled Board with all parts soldered - Ready to go.
Enter your email address if you'd like to be notified when Si5351 - 3 CHANNEL SIGNAL GENERATOR with SWEEP can be shipped to you:
$59.00
$69.98
$53.00
$80.00
$56.99
$75.00
