High Frequency DMX 512 decoder / dimmer for CV LED strips tapes modules RGB RGBW
Designed by JB_LABS in Slovakia
What is it? DIN rail mountable 6 Channel DMX / DMX512 decoder AKA dimmer with stand alone feature, and with selectable PWM frequency 300Hz /1.2kHz / 4.8kHz / 9.6kHz. Why did you make it? To make peop…
Read More…DIN rail mountable 6 Channel DMX / DMX512 decoder AKA dimmer with stand alone feature, and with selectable PWM frequency 300Hz /1.2kHz / 4.8kHz / 9.6kHz.
To make people happy
High PWM makes your connected LEDs flicker free on cameras / video cameras Usable without DMX. Any PWM value for each output is adjustable by user
Specs:
-12V to 24V operation
-Max 6Amp/CH, Max 20A total*
-DMX connection: RJ-45
-POWER in/OUTPUT connection: Screw terminal, pitch 5mm, Max wire cross section 2.5mm2
-Output type: Open Drain (for CV LED strips / modules)
-Grayscale: 8bit
-PWM Frequency: User adjustable 300Hz, 1.2kHz, 4.8kHz, 9.6kHz
-Size: 60 x 82 x 35 mm
-Weight: 70g
*with proper ventilation
Features:
-User adjustable PWM frequency
-Mountable on DIN rail
-All parameters adjustable by buttons and 7segment display
-Standalone mode where user can set any static PWM value for every output 0-255 (works without DMX)
-Multiple Channel count settings: 1, 2, 3, 6
Special Features:
-Pads with DMX&5V power ready for connecting wireless DMX module
-DMX data High and Low LED indicators
-Power LED indicator for internal 5V and for input voltage
-Designed and made in EU
!! IMPORTANT: Steel DIN rail shown on pictures NOT included !!
Enter your email address if you'd like to be notified when SUDOKU dimmer, 6CH High Frequency DMX 512 decoder can be shipped to you:
$18.50
$9.90
$119.99
$150.00
