Based on a simple NE555 Timer IC for synchronous inverted output, 500mA (1A peak) Output, Effective for low power timing applications
Designed by Homebrew Electronics in United States of AmericaThis product is no longer available for sale.
Welcome to the Homebrew Electronics Store!
All products are fully original, hand-assembled, and tested.
500mA Continuous power, inverted output, DC Motor Controller based on the NE555 Timer IC and 2 TIP-120 Darlington Pair Transistors NE555 Timer: Datasheet TIP-120 Darlington Pair Transistor: Datasheet…
Read More…500mA Continuous power, inverted output, DC Motor Controller based on the NE555 Timer IC and 2 TIP-120 Darlington Pair Transistors
Dual Motor header output for use with standard JST connectors
Stand-alone circuit board compatible with most low power, high RPM, brushed RC motors
Single-phase, timed, and inverted power output controlled using a simple tactile switch
$74.00
$14.99
$3.35
