$297.00
$200.00
$11.99
What is it? It is a Raspberry Pi Zero hat that puts the Microchip RN2903A LoRa module onto the Mini UART port of the Raspberry Pi Zero. Note: Mini-Uart shell in/out has to be disabled and HW UART to …
Read More…It is a Raspberry Pi Zero hat that puts the Microchip RN2903A LoRa module onto the Mini UART port of the Raspberry Pi Zero.
Note: Mini-Uart shell in/out has to be disabled and HW UART to be enabled. This hat has been tested with the Raspberry Pi Zero.
The board has a prototype area where you can build circuits like adding sensors, etc. You get access to 8 GPIOs on the RN2903A(some are analog in) 3.3V and GND.
At purchase you get the option to select which antenna path is populated u.FL or SMA(Both options include an antenna) and what header you want either female or male header.
To have another option to make LoRa projects.
Enables Raspberry Pi users to get into the LoRa world. Ships using Correos de Mexico, slow but cheap, tracking number included.
$18.99
