Light up LED on a strip according to audio input. Drive waves or light up the full strip. Use static mode if you want to light up the strip
Designed by Kallio Designs in Finland
Audio Input LED Driver for WS2813 LED strip Light up LED on a strip according to audio input. Drive waves or light up the full strip. Use static mode if you want to light up the strip without audio i…
Read More…Light up LED on a strip according to audio input. Drive waves or light up the full strip. Use static mode if you want to light up the strip without audio input. Compatible with WS2813 led strip.
Wave patterns Wave intensity will vary slightly depending on music amplitude. Colors range with audio input frequency from red – green – blue.
Same as Mode 1, but affects all LEDs on the strip (maximum defined in the characteristics -section).
Selectable color and brightness.
Available from many vendors, for example Elfa Distrelec: https://www.elfadistrelec.fi/fi/ws2813-rgb-led-strip-30-leds-rgb-5v-9w-1m-seeed-studio-104020108/p/30121593
Enter your email address if you'd like to be notified when Audio Input LED Driver for WS2813 LED strip can be shipped to you:
$9.98
$9.00
$7.95
