MCP23017 GPIO chip Break out Board (BoB) with on-board wire connectors, DIN rail mounting and indicator LEDs
Designed by Kallio Designs in Finland
MCP23017 GPIO chip Break out Board (BoB) with on-board wire connectors, DIN rail mounting and indicator LEDs GPIO BoB provides 16 inputs or outputs that have been routed to spring-cage PCB terminal b…
Read More…GPIO BoB provides 16 inputs or outputs that have been routed to spring-cage PCB terminal blocks. The device has two interrupt outputs.
The product can be mounted on a 35 mm DIN rail and control interface is I2C bus, commands according to MCP23017 specification.
Enter your email address if you'd like to be notified when MCP23017 Break out Board can be shipped to you:
1-4 | $99.00 |
5-9 | $39.00 |
10+ | $29.00 |
$19.95
$34.00
$14.50
