Powered by USB-C, controlled with your Smartphone. The easiest motor integration on the market!
Designed by Kayser Motors in Hong Kong
Unleash your creativity with the easiest motor integration for any DIY project - just plug in a USB-C cable and wireless control speed, direction, and more from your smartphone. With our custom-de…
Read More…Unleash your creativity with the easiest motor integration for any DIY project - just plug in a USB-C cable and wireless control speed, direction, and more from your smartphone.
With our custom-developed smartphone app, you can take full control of the motor directly from your device - no complicated wiring or programming required.
Simply connect the motor with a USB Type-C cable, and you'll have instant access to all its advanced features. You can configure custom speed profiles, set precise RPM levels ranging from 500 to 8000, and even program timed sequences - all from the palm of your hand.
And the best part? Once you've dialed in the perfect settings, you can send the configuration to the motor itself. This means the motor can run autonomously, without needing to keep your phone connected. Your project can continue operating even when your device is not present. Our integrated circuitry will automatically regulate the voltage, ensuring safe and reliable operation no matter what type of power source you choose. This flexibility eliminates the need for bulky external power supplies, keeping your projects compact and portable.
Need to take your project on the go? No problem. This motor can easily connect to a power bank, allowing you to enjoy all of its features without the need for a fixed power outlet.
If you're building a battery-powered application, simply plug the motor directly into your power bank. Your power bank will provide the necessary power, transforming your project into a self-contained, mobile solution.
And if your project's power source ever runs low, it's as simple as replacing or recharging the power bank. This ensures your creations can keep running, even when you're away from a traditional power source.
The versatility of this motor's power options means your innovative ideas are no longer limited by location or access to electricity. Take your projects anywhere and keep them running with ease.
Enter your email address if you'd like to be notified when USB-C smart brushless DC Motor can be shipped to you:
$134.99
$18.50
