Volvo XC/V 70 FaceLift back tail LED lamp module (30674783 part replacement)
Designed by Kliopp in Lithuania
Volvo side marker This is a 30674783 part replacement. It fits in Volvo V70, XC70 2005-2007 Face Lift lamps. The circuit is almost the same as original Volvo product. With these modules You will get …
Read More…This is a 30674783 part replacement. It fits in Volvo V70, XC70 2005-2007 Face Lift lamps.
The circuit is almost the same as original Volvo product. With these modules You will get a new cables.
Also you can buy a cover for module. This cover comes with the compression foam and fits for both sides. All you need to do is to peel off the protection film of the foam and attache to the correct side of the cover. Then trim the excess foam and it's ready to be assembled together with the LED module.
Red or White wire is positive 12V. Blue or Black wire is negative.
Incorrect installation can lead to the damage of your vehicle electronics. You are taking full responsibility by installing and using this device.
How to remove lower tail light:
https://www.youtube.com/watch?v=WjUzRAV4dDA
https://www.youtube.com/watch?v=goZUbRc6gUo
How to change the module (in French):
Enter your email address if you'd like to be notified when Volvo XC70 V70 back tail lamp module 30674783 can be shipped to you:
Return cost (including customs and other taxes) is always payed by the customer. We are not responsible for unclaimed packages. In case package was returned due to unsuccessful delivery, we will refund only the price of items but not the shipping cost.
We offer only the cheapest shipping method with a tacking number. It means that delivery time in some cases can take much longer than expected.
Our shipping methods is cheap but slow. Keep in mind that delivery time cannot be predicted.
1 | $21.00 |
2 | $20.00 |
3 | $20.00 |
4 | $19.00 |
5 | $19.00 |
6 | $18.00 |
7 | $17.50 |
8-9 | $16.00 |
10+ | $15.00 |
Product: (4.75)
Documentation: (4.62)
Communication: (4.88)
Andrejs | July 31, 2023
David | Nov. 22, 2021
Tadas | June 2, 2021
Juris | Feb. 6, 2021
Rafael | Jan. 31, 2020
Matek | Nov. 10, 2019
Ralf | June 1, 2019
Erik | April 23, 2019
$17.67 $19.00
$46.21 $49.69
$164.89
