This USB A power blocker stops your 3D printer's screen from being powered from the USB cable.
Designed by Koala Creations in AustraliaThis seller is taking a break. Sign up below to get an email when they're back!
What is it? This is a simple, inline adapter that you can plug into any standard USB A port, and plug a standard USB A cable into. This blocks the 5v power signal from reaching the other side. Use it…
Read More…This is a simple, inline adapter that you can plug into any standard USB A port, and plug a standard USB A cable into. This blocks the 5v power signal from reaching the other side. Use it on a 3D printer, CNC machine, or your custom Arduino and ESP8266 or ESP32 projects!
Various USB devices may be plugged into your computer or raspberry pi all the time. Sometimes you don't want these devices to receive power via USB. Why? You may want the power light or screen to only come on hen the device is turned on. You also may only want to use USB for communications, and not for powering your project.
Nothing! It's literally a USB A male to female connector without the 5v line connected. What you get is a neat little package that's ready to go!
Enter your email address if you'd like to be notified when Power Blocker (USB A to A) can be shipped to you:
Thanks for your purchase! Like you, I hate waiting for my new gadgets! I'll do my best to have your order shipped within 48 hours and will let you know if it takes any longer. Thank-you.
1 | $6.50 |
2 | $6.00 |
3+ | $5.00 |
$13.50 $15.00
$5.60 $7.00
