Common Emitter Amplifier
Designed by KS Electronics in United Arab Emirates
Bipolar junction transistor amplifier This is a two layered PCB of common emitter amplifier circuit. It is a bipolar junction transistor amplifier. Small signal amplifier is a single stage transisto…
Read More…This is a two layered PCB of common emitter amplifier circuit. It is a bipolar junction transistor amplifier. Small signal amplifier is a single stage transistor amplifier. +Vs is the DC power supply and VIN is the AC power supply. Oscilloscope can be connected to VOUT to see the amplified result. Connectors, resistors, capacitors and BJT can easily be soldered onto the board.
Enter your email address if you'd like to be notified when Common emitter amplifier can be shipped to you:
$13.37
$19.50
$17.99
