The KT-IOT Board is an arduino compatible cellular IoT board which utilizes Quectel’s modem and Espressif Systems microcontroller.
Designed by KT Boards in United States of AmericaThis seller is taking a break. Sign up below to get an email when they're back!
The KT Board is an arduino compatible cellular IoT board which utilizes Quectel's BG95-M3 modem and Espressif Systems esp32-c3 microcontroller. The BG95-M3 is a series of multi-mode LPWA modules supp…
Read More…The KT Board is an arduino compatible cellular IoT board which utilizes Quectel's BG95-M3 modem and Espressif Systems esp32-c3 microcontroller. The BG95-M3 is a series of multi-mode LPWA modules supporting LTE Cat M1/Cat NB2/EGPRS and integrated GNSS while the ESP32-C3 is a single-core Wi-Fi and Bluetooth 5 (LE) microcontroller SoC, based on the open-source RISC-V architecture. Combining the BG95-M3, esp32-c3, and additional features will take your project to the next level. Attach sensors, motors, and other electronics to the open ports. The built in 4G, wifi, and bluetooth gives you the ability to connect to your project anywhere. The possibilities are endless with the KT board, so what will you build with it?
Message us for discounts on bulk orders!
What’s Included:
Highlights
Features:
Enter your email address if you'd like to be notified when KT-IOT 4G LTE and GPS Development Board can be shipped to you:
1-9 | $62.99 |
10-99 | $64.99 |
100+ | $62.99 |
$55.95
$16.95
$34.90
$46.00
